Anyone having issues with hi-hat edge and splash triggering inappropriately?
I’m using the Evans db One 14" hi-hat, but I’m noticing some sensor misreadings in SP and/or Superior Drummer 3 when doing regular pedal closes (using a Tama Speed Cobra 315 Hi-Hat Stand). A couple of things I’m noticing:
  1. Looking at the sensor input screen in SP (so, before any MIDI is being generated), I notice that closing the hats with my foot pedal will often trigger the hi-hat “Edge” zone (and sometimes other zones as well) rather than just the pedal-close zone/sample. I can’t seem to predict exactly when/why this happens, since very similar sequential pedal closes will intermittently cause this.
  2. Pedal closes that are on the softer side tend to very reliably trigger a hi-hat “splash” even when my foot remains in the fully closed position. (I have noticed this in Superior Drummer, and I haven’t fully tested using only SP, so this could some kind of MIDI or settings issue in Superior Drummer - there is a splash sensivity setting there, but adjusting that doesn’t seem to affect this issue).
Just wondering if anyone else has noticed this and has any tips for correcting? One thing I’m wondering is that my bottom hi-hat cymbal has a half-inch hole in it, back from when I was using it with the Zildjian Gen16 system and wanted to route the cable through the bottom hat…I’m not sure if that’s messing with the acoustic signal getting sent to SP).
One thing that might help correct issue #1 above is if we could have the ability to manually train the cymbals (even the Evans db Ones), since I could null out the sound of the pedal close for the Edge zone. Hoping that feature gets added soon!
No issues using pure SP2 system. Please add to the title : in Superior Drummer 3 for better understanding. Thanks
Kindly, please reread my post. It’s a combination of issues only in SP2 as well as in SD3. I’m noticing incorrect zone detection solely in SP2.
Hi, I read it. I understand. I am not having any issues using only SP2. That’s why I have pointed SD3. Cheers Arek
