Audio inputs active in second portal?
Hi can I use the audio inputs in the second portal for piezo triggers? They still show up in the P2 expansion card…..It would be amazing if you could make these work as actual audio inputs, it would really challenge Yamahas ead50 for getting 2 room mics and kick and snare mics with the triggers on tom’s for blending with sounds in the library or sd3.
