Does the training save with the .sps file or is it more of a global setting in that if I clear the pad training (“all pads” in this case), it is cleared out not matter if I open a different set?
For instance, say I’ve got a kit I just trained with brushes, can I make a copy of the set/kit but have trained with sticks that I could switch to?
Hi Craig,
The drums models are not stored as part of the set. They are individual files that are stored on your computer. On the mac they are at:
/Documents/Sunhouse/Sensory Percussion/usermodels
As far as loading different trainings and sets, they are done independently. So if you have a training with brushes, you can always access it from the “models” dropdown in the mixer no matter which set you have loaded.
I hope that helps. Let me know if you have any other questions.
best,
