Hey y’all!!
While Im using headphones, the audio level is ridiculously low. I barely hear any sound even the level of my interface is turned to the max… that makes working with headphones useless, and I can’t figure it out, even though it must be just a simple thing.
Anyone knows what Im doing wrong?
I have Steinberg UR44 with a Mac.
Thanks!!
I have exactly the same issue! I tried turning up the level of the channel on my interface, but with no change in volume.
I’m using an Apogee Ensemble, so I wouldn’t think it’s a problem with the interface.
Hey there,
I think there is possibly a setting within the routing/mixing software of your interfaces that is causing this issue, but I can’t know for sure without actually seeing your setup. Can you send a short video or description (preferably with screenshots) of:
- Your audio settings in Sensory Percussion
- The routing/mixing software for your interface
To support@sunhou.se?
We’ll get you sorted out from there.
-Steven
