I’m having a bit of trouble understanding how I can adjust the threshold of each sound to eliminate cross talk…is that the right term?
Sometimes when I hit the edge, I’ll get the edge and center sound. Is that a matter of going back and retraining my drum or something I can adjust? I feel like my playing on each (center, edge, rim tip, rim shoulder, etc…) is pretty consistent yet I still hear two sounds more often than not. This happens on both my silent stroke heads and my regular batter heads.
Let me see what I can do to help you with this. First, I need some more info to really get to the heart of what’s going on. Could you give a little more detail on when this is happening? Does this happen when you are playing just the drum by itself, or when you are playing other drums? Playing fast and/or slow? In general, cross talk happens between drums, not within the same drum. Each Sensory Percussion drum is monophonic - so each hit can only result in 1 pad being triggered (unless you have blends turned on)
As simply as I can put this when I hit the center of the drum I seem to trigger both the center sound and the edge sound. I figured “cross talk” was the wrong term. But this seems like it could be a blend issue? I’ll trouble shoot this and let you know. Thanks a ton for the links here and for a great product!
