I found a bug. I have a pad set up to trigger changing kits when I use this trigger to change kits my CPU goes thru the roof and causes distortion. This only happens when I use a trigger ,if I use my mouse, it does not happen. It goes from about 20 or 30% cpu to about 80+ percent of CPU and then goes back down when I use the mouse to select that same kit. Yes I’m up-to-date. Also, this happened with the last version too. I just didn’t get a video and I did message you guys, you wanted a video. I do have a video, however, I can’t upload the format so, can I em it to you?
Hi @West_Brad thanks for the bug report. It would definitely be helpful to see a video. You can email it to support@sunhou.se or upload it to dropbox/google drive, etc and send a link to support@sunhou.se
Our latest beta, 2.8, includes some big optimizations. Would you be willing to try this on the beta and see if you get the same results?
Thanks for the quick reply. I sent a video to the Sun hou.se email. I’ll try to download and test the beta. It might take me some time.
