Hey all, we just pushed out a new beta with updates to the Plugin. The release notes are below – let us know how it goes for you.
PLEASE NOTE: the plugin is now installed from the settings window in the General tab.
Check out the manual page for all all sorts of info: How To Use the Ableton Live Plugin | Sensory Percussion 2 Help
Version 2.1.8-beta11
This beta has fixes for the VST3 Plugin for Ableton. It’s now installed from the General tab in the settings window. This release also has some minor bug fixes and additions. Let us know how it goes!
Other changes:
- You can now use MIDI Program Change to control which set is active in Sensory Percussion
- The Pitch & Scale transpose panel now correctly affects MIDI messages on the MIDI Router module.
- The changelog popup (this one!) is now more readable
- The EQBand and Filter effects had some icons in the wrong spot. Those are fixed.
- New keyboard shortcuts for switching to Play/Edit/Mix view (cmd-1/2/3)
