Hi All,
This update is a release candidate for 2.3.0 – it has a lot of polish, fixes and some new goodies since we released beta5. Check it out and let us know what you think!
Headline features in the release:
- Global Sets
- Global Stop button
- New Pads input type & Grid Pads controllers
- New “Random | Step” modulator
- Set transitions
To install the beta, just open the beta app and you’ll get an in-app notice or head to https://sunhou.se/downloads/beta .
If you’re not part of the Beta channel and would like to join, send an email to support@sunhou.se (you just need a valid SPv2 license and a willingness to help test new stuff).
Added
- Added Global Set, with always-playing objects
- Added set transitions options
- Add MIDI pads surface type hardware input
- Add grid pads controller module type
- Added “Random | Step” modulator type
- Added global stop button
- Added “remember step” option to Sequencer
- Enable modulators panel on MIDI CC and note generators modules
- Add filtering options for OSC output
- Add pitch & scale panel to MIDI router
- Add note length to MIDI router
- Add a “copy to siblings” helper function
- Enabled assignments from any source to any target
- New input range adjustment parameter on Macro assignments
- Added a new pickup element and sensor setup page to Guided Setup flow
- Added Start/Stop controls to the sampler trim view
- Added new “What’s New” guide
- Added inspector tab to MIDI hardware input module
- Added velocity sensitivity to play buttons
- Implemented new set list selector dropdown
- Added “command + r” to rename selected module
Changed
- Updated portal Windows driver to v5.70.0
- Set metro to default to “off” when created
- Updated “velocity” mode to “note velocity” in midi modulators
- Removed “save” from plugin and passed “command+s” directly to Ableton
- Improved defaults when assigning to buttons for various input types
- Update labels for modulator type and surface type in assignments GUI
- Improved UX for next/previous set button assignments
- Rehide pitch and scale on sampler
- Ensured plugin GUI does not create extra windows beyond the main one
- Show full name in filter effect type combobox
Fixed
- Fixed waveform update issue in sample trim
- Fixed drag-assigning to trigger button starting in continuous mode
- Double-clicking on assignment target output now uses param default
- Fixed bug where shift-dragging on param numbox opened assignment edit window instead of modifying drag speed
- Fixed issue where default shortcuts get unmapped
- Fixed assignments on smooth and invert params
- Resolved paste order issues
- Fixed issues with sequencer index assignment behavior
- Fixed possible crash with assignment MIDI learn
- Fixed user settings with unmapped keyboard shortcuts
Library Updates
- Added Tom 3 virtual inputs to most sets–now if you have 3 tom sensors, most kits will work right off the bat
- Added “augmented ghost note” option to most of the Electric Drums Kits
- New sets: “Augmented sol”, “Augmented Zukunft Drums”, “stereo power sol”, and “Combo Drums” added to the Acoustic Drums pack.
- Minor fixes, mixing, and upgrades to sets across the library
