2.3.0-beta5 just released
Hi all,
We have a big new beta for you to try with some headline features. First off is Global Set. Whatever you put in the Global Set will always be active. This is perfect for things like MIDI, or analog inputs like a vocal mic that you always want present in your session. We also have new set transition options (right-click on the set); a new Grid-type hardware input and pad controller module, this is great for using an SPD as an input for triggering sounds in SP; a really cool new modulator type called “Random | Step” and a ton of smaller improvements.
Now by default, switching kits will reset your sequencers to step 1. There’s now an option to change this behavior.
We’re still tweaking things and making improvements so please share your feedback. The documentation for these features isn’t live yet, but I can answer any questions you might have here.
To install the beta, just open the beta app and you’ll get an in-app notice or head to https://sunhou.se/downloads/beta .
If you’re not part of the Beta channel and would like to join, send an email to support@sunhou.se (you just need a valid SPv2 license and a willingness to help test new stuff).
Added
  • Added set transitions options
  • Added Global Set, with always-playing objects
  • Add grid pads feature
  • Add MIDI pad surface type hardware input
  • Added “Random | Step” modulator type
  • Added remember step option to Sequencer
  • Enable modulators panel on MIDI CC and note generators modules
  • Add filtering options for OSC output
  • Add pitch & scale panel to MIDI router
  • Add note length to MIDI router
  • Add a “copy to siblings” helper function
  • Enabled assignments from any source to any target
  • New input range adjustment parameter on Macro assignments
  • Added ability to forward OSC to external listeners with a custom address
  • Added a new pickup element and sensor setup page to Guided Setup flow
Changed
  • ensured plugin GUI does not create extra windows beyond the main one
  • Show full name in filter effect type combobox
Fixed
  • fixed waveform update issue in sample trim
  • fixed drag-assigning to trigger button starting in continuous mode
  • double-clicking on assignment target output now uses param default
  • resolved GUI state mismatch in mixbus list
  • fixed bug where shift-dragging on param numbox opened assignment edit window instead of modifying drag speed
  • fixed issue where default shortcuts get unmapped
