2.6.0-beta16 just released (Cymbals + Hot Swap!)
Hey all, we just pushed live 2.6.0-beta on the beta channel. This is a big one! The production release will be out in just a bit as well, but we thought some of you might like a sneak peak.
This release brings support for the new cymbal sensors, and also brings some pretty huge changes to how you can use and remix Sunhouse presets. We’ve introduced “Instruments” and hot swapping, which a super fun way to build kits. This release also has a ton of new stuff to explore in the library – new cymbals and hi-hats and a bunch of new presets. Read on for the full details.
Added
- Support for new cymbal and hi-hat sensors
- New Cymbal and Hi-hat Pad Controller modules
- New Hi-hat Pedal Control module
- New instrument tags and instrument tab in the Library
- Updated Play View layout with drumset view and layer filtering
- New Drumset Layout settings page (to change which drum matches which input filter tag)
- New Hot Swap panel in Play View and Edit View
- Added a stop button to the Set Volume panel in Play View
Changed
- New sets now create a grouped drum set instead of individual pad modules (for hot swapping)
- You can now delete and reorder layers in the Play View
- You can now drag items from the library into the Play View
- We've updated the default filters for new modules: 'All Snares' becomes 'Snare 1', etc.
- When selecting from the Input Filter dropdown, filters are now a single-select action. You can hold cmd/ctrl to select multiple filters.
Fixed
- Prevent possible crash at exit
- Fix regression on mouse wheel events
- Fix crash when undoing the deletion of the last set
Sounds
- Every Core Library and official Sound Pack set now has a hi-hat, ride cymbal, and crash cymbal
- Added hyper detailed multi-sampled mappings of four hi-hats, four ride cymbals, and four crash cymbals:
  - Istanbul Agop Hi-Hat 14"
  - Paiste Signature Hi-Hat 14"
  - Timothy Roberts Landmark Hi-Hat 15"
  - Zildjian 1940s K Hi-Hat 13"
  - Bosphorus Master Series Ride 22"
  - Collingwood Ride 22"
  - PGB Oyster Ride 21"
  - Timothy Roberts Prism Ride 20"
  - Istanbul Agop Crash 18"
  - Paiste 602 Thin Crash 22"
  - Royal Craftsman Crash 17"
  - Zildjian Avedis Crash 18"
- Remixed Acoustic Drums sets for more playability, and remixed all sets in Core Library and Sound Packs for more head room
- Added eight new sets to Electro Melodic: "pentaAdditiveAdventure", "clusterTones", "ghost lineage", "desert snails", "strange dogs", "Arpeggiated Estuary", "Tonal Creature 1", and "Tonal Creature 2"
- Added a new set to Chord Sequences called "Hype Cycle"
- Added four new sets to Acoustic Drums made from "Frankensteined" material of existing multi-sampled material
