2.6.1-beta1 just released
Hey all, this release is hot on the heels of 2.6.0 and makes some important fixes. Thank you to everyone who reported these. This beta should address all the reported issues EXCEPT for using cymbals in plugin mode on Windows. It works fine in standalone. This will be fixed in the next beta coming very soon.
Let us know if you run into any other issue with this release. Thanks!
And a side-note on the latency parameter – this feature was actually not intended for public release, so we are removing it. We used it internally when we reduced latency with the 2.5.0 release, but in it’s current state it can cause some serious problems. But we know many of you like the idea of this level of control, so we are going to work on it and bring it back in a better way.
Version 2.6.1-beta1
Fixed
- remove latency parameter
- fix compatibilty with macOs 10.14
- fix Program Change MIDI messages
- fix MIDI output to host in plugin
- remove unneeded training info for cymbal
- fix incorrect default threshold value for sensors
Changed
- improve loading time of samples
- reduce number of background threads
- improve preformance for large sets
