Hello everyone, anyone else having issues where the standalone Windows software opens, and then immediately closes after? 2.6.1 worked fine. I tried fresh installing 2.6.2 but got same thing again
Yes, I can confirm this bug.
The app is starting and gets shut down.
Hello, there may be an issue with the shortcut to the app that appears in the start menu. We’re investigating.
Can you try opening the app by double clicking directly on the .exe? You can find it here:
“C:\Program Files\Sunhouse\Sensory Percussion 2\Sensory Percussion 2.exe”
You are correct.
All works when opened your way.
Arek
This work around works for me as well, thanks!
