2.8 and new sound pack updates
Thanks so much for the massive update that is 2.8.
When I update to 2.8 should the new sound pack updates also be installed?
Also it mentions instrument presets for Somnambulist. I don’t know what that is?!!
Thanks for any help.
Roy
@roycutler I agree about the update, I looked at my sound pack files and see that I hadn’t updated many them. I think I am going to re-download and install all of these and see how it works.
@roycutler Also that ‘Somnambulist’ is the name of one of the paid sound packs.
Hi @roycutler and @davpelton,
The 2.8 update included changes to 12 out of 14 of the included packs, and one of the paid packs (Somnambulist, as you guys mentioned).
The updates to the packs this time was mostly centered around adding .spp files (instruments).
So – if you have the packs installed and they’ve been properly updated – you should see a list that looks like this when you right click on a drum in Play view or a blank spot in Edit view:
The only pack this time that should require a reinstall is the Cymbal Expansion. It’s a special case because it involves a large number of new samples (the raw material of the new Sabian cymbals), that we wanted to avoid inflating the size of the Sensory Percussion 2.8 installer.
Feel free to let us know at support@sunhou.se if you think the packs didn’t update properly when you installed 2.8. We’ll probably ask you for a diagnostic report, which will give us the particulars about your system and may help us understand what happened.
@stevenz Thank you for this information!
Hi @stevenz, is it possible to add a version number to the sound packs available at present? That would help a lot, or build a forcing mechanism on the app to ask the user to update? Thanks Arek
Hi @Arek_z_rodu_Kulesza,
The packs often update when the app updates. But anything you have saved to a session does not get updated. We like to update the packs when new features come out and to be able to fix or improve things in the sets and instruments, and sometimes even add new sets and instruments.
So you can save the pack to a session file with your own versioning system and it will not be updated
Thanks for a prompt response.
Hi Steven,
Can you remember me how to properly update a sound pack please ?
Thx
Hi @Bo33,
The packs update automatically with software updates. But if you want to check to see if you have all the packs installed, login to our website where you can download them.
I just did it. I redownload the Cymbal Expansion Pack from the website. Once I clicked on the file it open the SP2 software. The second time I clicked on the downloaded file I got a pop up window on the SP2 software asking if I wanted to overwrite the expansion pack. I did, and it reinstalled the cymbal pack and if I’m correct it now has more cymbal offerings. I wished I would have taken a screen capture of the pack before the rewrite to make sure though.
Hi @tgfoyl1472,
Sounds like it worked! To be 100% sure you should see these eight new Sabian Cymbals in your Library/Instruments:
