A question regarding "normal" drum triggers and interfaces
I have a lot of older standard drum triggers and trigger interfaces. Can these be used via MIDI to trigger sounds from the SP2 module? Can the SP2 midi out trigger sounds within Superior Drummer? Sorry, I am trying to plan out some things and want to maximize as much as possible the system with what I have at my disposal. Any help with this topic is appreciated.
Yes, definitely. If they can send MIDI to SP, then you can use them in the software to do all kinds of things. There’s a Pad Input type that is specifically for these kinds of MIDI devices - triggers, SPDs, etc. Pad Inputs | Sensory Percussion 2 Help
And, yes, SP2 can be used to control Superior Drummer. We have a template available to help with that, too. You can read more about that here: Sensory Percussion 2 to Superior Drummer 3 Template with Cymbals - #24 by Aka_Wayne
Awesome thanks.
