Hi @West_Brad, apologies for the late reply. In addition to the plugin guide in our user manual, we also have a plugin tutorial video that shows the step-by-step setup for the plugin inside of Ableton:
Note: In the video, we’re using Ableton Live Suite, but the same process will work if you’re using Live Lite. You will just be limited to using 8 tracks total.
I’d suggest following this video as closely as possible and if you run into trouble, please describe your issue as specifically as possible, preferably including screenshots/screen recordings of your Ableton session. You can drop those here, or if you send them to support@sunhou.se, we will likely get to it faster and make sure your issue is resolved.
For some background, we call the Sensory Percussion plugin an “Ableton plugin” because Ableton is the only DAW with which can guarantee full functionality. It’s a VST3 plugin, which means it can be loaded in other DAWs like Reaper, but we’ve found that every other DAW has inherent limitations.
For Reaper, we did work on an SP2 plugin template and found that you can get basic functionality, but Reaper’s input monitoring settings meant that the sensor audio (the sound of the actual stick hitting the rim/head) was inseparable from the output of the plugin, meaning they get recorded to the same output track(s). If you want do your own research into Reaper, here are those templates:
SP2 Reaper Templates.zip (244.6 KB)
But again, you’ll have a much easier time using the plugin in Ableton than you will in any other DAW.
Alternatively, if you have an extra audio interface/recording device handy, you can record the output of the standalone Sensory Percussion 2 app (not the plugin) by physically connecting the main or aux outputs of the EVANS Portal to the inputs of your interface.
With this method, you’re essentially recording Sensory Percussion the same way you would an SPD/guitar pedal/synth, and you can use whatever DAW you like. Here’s a diagram showing that setup:
And lastly, we are working on a built-in recording feature that we’re hoping to have ready in the next month or so. We’ll be releasing it to our Beta users first, so if you’re interested joining the Beta program, shoot us a message at support@sunhou.se.
Hope that helps!
