Adding tempo based delay times
It would be nice if the time based effect times were able to be set in note-value increments based on a bpm. I understand that there isn’t a master clock running to sync things to. But just being able to type in a tempo on a delay and then switch between 1/8, dotted 8th, 1/4 etc would be music easier than doing the math to ms all time.
Also could then use a random/step or lfo to automate between different note divisions.
Hi @clarkbaechle totally agree. We’d like to to have this, too. It’s on our list to get to.
In the meantime, you can actually type values into the delay time text box in bpm. For example, if you type “180 bpm” it will convert it for you to ms.
Great. That is a nice work around for now. Thanks!
