Is there a ‘‘All off’’ / ‘‘Kill Switch’’ button somewhere in the program?
in case a long sample is hit accidentally, to be able to assign a part of the kit to stop all pads, not just mute them because if it is a long pad, you would still have to wait until the pad is done before unmuting.
I searched in the program, and the manual.
Etienne
Yo Etienne!
One way I’ve found to do this to assign the desired sample to a choke group, and then assign the desired region to the same choke group, but with no sample in the sampler. For example, you have a long tone going on the floor tom rim, and you want to mute it, so you do a stickshot on the snare, and with no sample assigned to the snare stickshot sampler, you’ve essentially muted your floor tom rim sample. I hope that helps…
-Max
That’ll work.
We’re also adding a choke button to the master channel on an upcoming beta release. Will keep you posted.
Right, I used to to this on the spdsx, but forgot I could do it with this too.
Thanks !
