I have an Analog Audio Input created on my physical Inputs labeled as a Mixer. It has signal.
The problem is that the Audio Input Module allows the Input to be heard but doesn’t actually control the audio. The Volume has to be manually adjusted from the Input list. The Module fader does nothing. The Module Mute also does nothing. If I delete the module the audio signal IS removed from the kit, but I’m not sure why the module has no control of the signal beyond allowing it through.
