Any way to output 4 separate tracks?
Currently recording a record with my band and wondering if it is possible to send 4 seperate outs for each sensory drum within ableton, I have the input as the sensory portal, and the output as my scarlett interface, we are then trying to run outputs from the scarlett interface into a board to be able to capture 4 different rtacks. I would like to be able to create four seperate audio outputs so that we can alter the sounds of each drum within the daw that we are recording to but the routing of the sensory template makes this very confusing. any help would be appreciated!
