I’m having issues with the Blends section of the editor. When I have one pad selected in the Pad Vizualizer and select another pad in the Blends section to make it part of a blend it does not light up as highlighted right away. I have to click on another pad in the Pad Vizualizer and then click back on the original pad in order to see the change I have made. The blend works but it just doesn’t show up visually right away in the editor. Is this a known bug?
Hi there,
Yes, there does seem to be a refresh bug here. Thanks for pointing it out. As you mentioned, you have to click on another pad to get the blend panel to refresh properly, but you should only need to do this once after clicking on a new drum channel.
Sorry for the issue and thanks for your patience with this. We’ll get a fix out as soon as we can.
Tlacael
