Cannot get the v1 Sensor to work inside the v2 Ableton Template
Hello!
I bought the v2 bundle with Evans portal, but i have one v1 sensor from before that I included in the set.
When i load in the Ableton template that you provided and set everything up, I get my v2 sensors to work properly, but I can’t seem to find a way to recieve any input from the v1 sensor. In the standalone application it works fine. How can i make it work?
Thanks,
Lav
Hello @lavisintheair!
I think you just need to change the routing of the template’s sensor input channels to be either Input 1 or Input 2 (depending on which combo jack you have plugged your V1 sensor into).
Here is the manual section on the I/O for the Portal: EVANS Sensory Percussion Portal | Sensory Percussion 2 Help
The V2 sensor inputs are channels 5-11. The Combo Jack inputs are channels 1 and 2.
So if your V2 sensors are plugged into the first 3 sensor inputs of the Portal, and your V1 sensor is plugged into Mic/Line A, then your sensor input routing should look like this:
Let us know if that does the trick for you!
