I recently purchased a new sensor, but noticed that some of the Sound packs are ready for an additional sensor. might I be able to add an additional pad where there are only three or four pads available? For example, some Sound packs are configured for only three sensors and some for four but if you buy a fifth sensor, there is not a pad available. Can I create an additional pad for that sensor?
Hi @Dlevhend,
Great question! Yep, you can drag and drop layers from the Library and reassign their input filter to match a drum in your setup. See the video below, where I go into the Library and drag a tom from Keine Zukunft into my working set (Black Cat Drums), and then adjust its input filter to Tom 3.
We’ve actually been discussing adding a 3rd tom to most sets in the Core Library and sound packs. Here’s version of the Core Library Acoustic Drums where we’ve done that.
5-peice-acoustic-mappings-with-toms.sp2 (4.7 MB)
I have the full 7 sensor setup. It would be cool to have a 5 tom sample setup (or more) in core sounds, though currently I just use the same sample and re-pitch it for each tom because it’s easier than finding multi tom sample groups.
