Copy and paste effects?
Is it possible to copy and paste effects? Often times there is an effect in a set that I like and I would like to use it in another set or in the global set. I haven’t found an easy way to do that. Am I missing something?
Hi @bustinbikes,
Yes! Just click on an effect (or any module) and select command + C on Mac (ctrl + C on Windows).
And then command/ctrl V on the effect panel of the destination module.
You can also select an effect (or any module) and copy/paste under Edit in the top menu. Or right click a module and select cut/copy/paste
Ok thanks! That’s what I expected but for some reason I couldn’t get them to paste earlier. I think I had to figure out what to have selected before pasting. For the global mix bus effects, it seems that I have to add an effect before being able to paste one. I also just found the paste(replace) option which makes that more streamlined.
