Copy Global set
Hello
I am a new to the Sensory percussion so …
Is there a way to copy and save the global set, so when you change session you dont have to start all over again? but could load the global set in to another session.
Best regards
Jesper
Hi @Jesper_Ottesen – thanks for you note. Tat’s not currently possible with 2.3.0, but it’s definitely something we’ve talked about adding. Are you hoping for being able to set a “default global set” or to just be able to copy/paste/drag in a previous global set from the library?
Thanks for your reply.
Hmmm… I dont know.
my situation is that I am new and trying different options of eg drum sizes, microphone input, line input. here it would be smart if I could save presets for the different drum/mic/line inputs, in order to be able to put together different global sets.
Hope that makes sense.
