Editing the Visual Drum Layout
How do I edit the Drumset Visual for Virtual Inputs in the Play Menu?
Just curious…it has too many drums showing. Can I remove Inactive Inputs from the visual or is removing the Input completely the only way to get rid of it?
(I have 2 Tom Sensor Inputs currently inactive, due to switching to cymbals. I might want to keep the inputs for later use, though they are currently Inactive via the “Power” button on their individual Input listing.)
How do I only show the desired drums inputs on the visual?
Plus there is a 2nd Snare that I don’t know where it even came from.
Someone please explain the editing window for the visual layout or did I miss it in an updated version of the online manual?
Hi @SacredBlasphemy ,
I started typing out an answer, but thought a video might be more helpful:
I should also add that if the number of hardware inputs you have is getting unwieldy, you can always save your inputs as a single file that you can load later, freeing you up to delete the ones you’re not currently using without worrying about losing the training you did.
Thank you. I also found the Drum Layout menu by the Audio Settings Menu under File.
Thank you! What about a fellow like me that has 2 kick drums? I like to set up my left foot kick as a snare, so I can play around the toms while keeping a kick/snare back beat.
