Evans Portal - Sensors input compatibility
I’m using XLR input 1/2 for drumset mics, and input 3/4 for my old Korg Wavedrum.
I’m using just 3 (maybe 4 in the future) V2 sensors on dedicated inputs.
I’d like to use the unused sensors input with other pad or kick trigger (like Roland PD-5 and KD-7) with a mono 6,3mm/3,5mm jack cable.
It is possible or I will damage the interface?
(I’m able to build custom cables if needed)
thanks a lot
Enzo fom Italy
