Exploring Software Without Portal
Does anyone know if it is possible to setup a kit and play with the sounds while the Portal is not plugged in. I want to play with different kits and adjust the sounds while I’m away from my home and was hoping I could do that by just clicking the drums under the “Play Tab > Virtual Inputs”. I’m assuming this must be possible but I might have it setup wrong to allow for this. Any clarification would be great.
Thanks :grin:
Hi Tyler,
I used to do that by simply clicking in the virtual inputs zones, in Edit view, show virtual inputs, click on pad zones you want.
I think it’s still working !
Cheers !
Bo
Sure thing
With the Metronome (new one in beta will be even better for this), you can run a sequencer that hits anything you want, without the portal.
