Hi everyone. I use my laptop to run SP, same computer I use for my day job in digital marketing. I wanted to reduce latency, but I kept having crackling problems at 64, and sometimes even at 128 sample rates.
I digged into the topic, first by following the Ableton guides Optimizing Windows for Audio and How to avoid crackles and audio dropouts. But it didn’t work.
I then turned to Gemini and ChatGPT and started a long conversation that took over a few days, and still kinda going for tweaks. I then asked the LLM to summarize everything that was done into a guide, which I am sharing here.
It’s written in a “help center guide” style, hence the language. I hope you find it helpful, and I recommend copy-pasting this guide into the AI tool you use and ask it to adjust it to your model.
Background & Use Case
This guide outlines a setup protocol for achieving stable, ultra-low latency (64 samples) in Sensory Percussion 2 while maintaining day-to-day usability for general work.
This specific configuration addresses a dual-use workflow: operating as a primary mobile workstation for digital marketing, video/image processing, and client meetings on battery power, while doubling as a low-latency audio processing rig for 30–60 minute drum sessions plugged into AC power.
Hardware & Software Specifications
The adjustments below were tested on the following system configuration:
Model: ASUS Zenbook UX3404VC
CPU: 13th Gen Intel Core i9-13900H (14 Cores / 20 Threads, Hybrid Architecture)
RAM: 32 GB LPDDR5
GPU: Intel Iris Xe (Integrated) + NVIDIA GeForce RTX 3050 Laptop GPU (4GB)
OS: Windows 11 Home (64-bit)
High-performance ultrabooks face two main challenges:
DPC Latency & Thermal Throttling: Real-time audio requires uninterrupted CPU cycles. High power bursts cause heat to build up quickly, forcing the CPU to slow down and creating audio dropouts.
Battery Drain: High-performance tweaks forced globally will keep discrete GPUs and high clock states active continuously, reducing battery life down to ~1 hour when unplugged.
The goal of this guide is to isolate performance configurations strictly to performance sessions, ensuring full 3–4+ hour battery life during daily work routines.
1. Operating System & DPC Latency Optimization
Background system tasks often take precedence over real-time audio threads, causing processing delays (DPC latency).
A. Airplane Mode while playing
Probably one of the easiest and most effective improvements you can make
Action: Before playing, enable Airplane Mode (
Win + A) and turn off Bluetooth. -
Why: Network adapters and Bluetooth controllers poll constantly in the background, creating driver interrupts (
ndis.sys/wdf01000.sys). Turning them off stops background processes during performance.
B. Graphics Driver Configuration (NVIDIA App / Control Panel)
Graphics drivers frequently adjust power states up and down, generating system interrupts that disrupt low-latency audio.
Action: Open the NVIDIA App $\rightarrow$ Navigate to Graphics $\rightarrow$ Select the Program Settings tab (do NOT use Global Settings).
Sensory Percussion 2.exe:
Set Power Management Mode to Prefer Maximum Performance.
Set Low Latency Mode to Ultra (or On).
EVANSPortalCpl.exe & Background Helpers (
driver.exe):- Set to Use Global Setting (Normal / Auto-Select).
Why this preserves battery: Restricting Prefer Maximum Performance strictly to
Sensory Percussion 2.exeensures the discrete GPU locks to high performance only when the drum software is actively running. Control panels and background drivers will not prevent the GPU from entering low-power sleep states when working on battery power.
C. Windows Graphics Settings & HAGS
Action: Open Windows Settings $\rightarrow$ System $\rightarrow$ Display $\rightarrow$ Graphics.
Enable Hardware-Accelerated GPU Scheduling (HAGS).
Add
Sensory Percussion 2.exemanually and assign it to High Performance (Discrete GPU).
Why: This offloads UI rendering memory management directly to the GPU, preventing the Windows kernel from interrupting real-time audio CPU threads.
2. Processor Power & Thermal Management (ThrottleStop)
Thin-chassis laptops allow CPUs to draw rapid wattage spikes ($60\text{W} - 90\text{W}+$), hitting thermal limits ($100^\circ\text{C}$) and triggering immediate clock-speed throttling.
A. Setting Power Limits (TPL)
Action: Launch ThrottleStop 9.6 $\rightarrow$ Open TPL (Turbo Power Limits):
Check Long Power PL1 and set to 65W.
Check Short Power PL2 and set to 85W–90W (PL2 must remain higher than PL1).
Uncheck Clamp next to PL1.
Why: Capping short bursts prevents the processor from pulling excessive power during transient hits, eliminating the initial thermal spike before cooling fans reach full speed.
B. Core Responsiveness & Sleep States
Action: On the main ThrottleStop screen:
Enable Speed Shift EPP and set the value to 0.
Uncheck C1E.
Why: Speed Shift
0forces the CPU to deliver full clock speed instantly upon demand. Disabling C1E prevents CPU cores from dropping into power-saving sleep modes between rapid drum hits.
C. Restoring Battery Operation
Action: Do not run ThrottleStop continuously. Only click Turn On when connecting to AC power for a drums playing session.
Why: When ThrottleStop is turned off, the CPU reverts to stock power management, scaling down clock frequencies and enabling core sleep states to maximize battery runtime during standard work tasks.
3. Bus & Power Plan Rules for Mixed Use
To prevent power management from putting connected audio hardware to sleep without causing global power drain:
A. USB Root Hub Power Management
Action: Open Device Manager $\rightarrow$ Expand Universal Serial Bus controllers.
Right-click USB Root Hub (USB 3.0) entries $\rightarrow$ Properties $\rightarrow$ Power Management.
Uncheck “Allow the computer to turn off this device to save power.”
Why: Prevents Windows from powering down the USB bus during silent passages or quiet performance moments, stopping wake-up latency delays on ASIO buffer streams.
B. PCIe Link State Power Management
Action: Open Edit Power Plan $\rightarrow$ Change advanced power settings $\rightarrow$ Expand PCI Express $\rightarrow$ Link State Power Management:
Set On Battery to Maximum Power Savings.
Set Plugged In to Off.
Why: Automatically powers down the PCIe bus to extend battery life when unplugged, while providing unthrottled bus communication when connected to wall power.
4. Physical Maintenance - Laptop Cleaning
Software configurations require adequate hardware heat dissipation to sustain target clock speeds.
Chassis Elevation & Auxiliary Cooling:
Elevating the rear of the laptop chassis by 1 inch improves intake fan airflow beneath the device, reducing internal operating temperatures 3-5C. Use a cool pad with fans, advanced cooling pads like llano V12 don’t fit every laptop cooling system - check your ventilation setup before investing in a more expensive cooling setup.
Positioning a small, USB-powered fan aimed on top of the computer aiming at the keyboard area can also help by actively dissipates surface heat trapped above the motherboard.
Warning: The following two steps require opening the laptop chassis. Opening a new laptop may void your warranty, so only consider this if your device is at least 2–3 years old. If you do not have prior experience with laptop hardware maintenance, it is strongly recommended to take your computer to a certified service lab.
Internal Fan & Heatsink Cleaning: Dust accumulation on internal radiator fins restricts exhaust static pressure. Opening the lower chassis to clear dust from fan blades and heatsink channels restores proper airflow.
Thermal paste changing (Repaste): Consider if your laptop is older than 2-3 year - factory thermal compound on high-wattage ultrabooks can degrade or suffer from thermal pump-out. Applying fresh thermal paste restores direct heat transfer from the CPU to the heatpipes.
- Result: Peak CPU temperatures dropped from constant 100C throttling down to an 84C - 92C ceiling under heavy load, providing ~15C of operating thermal headroom.
Pre-Session Checklist (AC Performance Mode)
Connect the laptop to wall power.
Enable Airplane Mode and disable Bluetooth (
Win + A). -
Elevate the rear chassis and position the auxiliary cooling fan.
Open ThrottleStop and click Turn On.
Launch Sensory Percussion 2.
When finished, close Sensory Percussion 2 and exit ThrottleStop to return the system to standard power-saving mode for mobile work.
That’s it - hope you find this guide useful! Please comments thoughts on how to further improve the setup for low latency.
