Has anyone installed the pickup element (Dot) onto a Roland Mesh Head or DWe Mesh Head?
I wanted to check here and see if anyone has installed the pickup element onto a Roland or DWe Mesh? I have a “hybrid” mismatched kit with both types of shell triggers and mesh brands along with rubber cymbals. My main interest in getting the SP2 system was for the cymbals to replace all my rubber cymbals but I figured why waste the sensors and the other capabilities of the SP software….
I am wondering if I could just installed the sensors onto my kit and just lower the volume of my Roland module and play (trigger) the portal although I am not using Evans mesh heads. If this works I may just add the outputs of both the portal and my module to a mixer and mix both sources into my headphones.
Thanks in advance for any help or insight.
I installed the pickup on a Roland mesh head and it triggers fine for all the zones.
Hey Kurt, is this mesh head is a two or three ply head please ?
I’m using Roland MH2 PowerPly heads on all my shells, so I guess these are 2-ply according to sweetwater
