I currently use an M-Audio Profire 2626 to line my sensors into the Sensory Percussion App. I’ve figured out how I can then send the audio to Logic or Ableton to record but I’m curious if anyone’s got a cleaner or easier solution than my jumble of logic.
And in case anyone thought it’s not possible, I’ll explain what I did.
I have four triggers, so I line them into inputs 5,6,7,8.
Then from the Master Output in the SP App, I output to channel 9. (right click mixer)
Then from the M-Audio application, on the Mixer tab, I send channel 9 to the Aux 1 by turning the dial all the way up. All the other channels have the Aux 1 dialed all the way down.
Then from the Router tab in M-Audio, I set the Analog Out 3/4 (Headphones 2) to Aux Send 1.
So now all of the SP audio is being lined out of the second headphone jack on the M-Audio.
Now I line out of the headphone jack and then back into the M-Audio into Channel 1’s Instrument Jack.
Now in Logic or Ableton, I can record all the SP Audio on Channel 1 without anything feedback back or bleeding into each other’s signal.
Anyone have a better solution? Requiring a cable to go out of the headphone jack and then back in feels ridiculous but I haven’t gotten anything else to work.
