I recently came across Hooplug, which seems like a particularly convenient way to swap between regular and mesh heads without losing tuning - curious if anyone’s had a chance to try these with SP to see if the sensors would fit alright given the additional hoop.
That seems like such a cool idea, for general playing. But it definitely seems like you would need to retrain every time you switched a new hooplug?
Change the head, vibration, frequency, Would change the way the shell vibrated - But maybe just slightly? Hard to imagine it wouldn’t change the way it interpreted.
Yeah! But you could save input settings and load those whenever you switch. It would take a bit, so not something I was picturing mid-track, but it seems like it does have potential to add some variety throughout a set.
Hi! I purchased two 14 Hooplugs specifically to have the ability to switch from acoustic head to mesh in a snap.
With the Die cast hoop I had no problem fitting the Sensory trigger and I must say it is a total change in use.
Cheers!
F.
This is so cool to see! Thanks for sharing.
