HI, Is it possible to play ‘double stops’? trigger two sections on the drum at the same time?
Hi @refoundsound, that’s not currently possible. If you hit two parts of the drum at the same time, the software will trigger the zone that is “closest”. It will basically choose one of the zones. Although in some cases, like rim shots, you are really hitting two zones at the same time (rim and the head). In any case, the software can’t trigger two separate zones at the same time, but it is capable of very fast flams.
Thank you!
