Interface latency for live performance
I want to buy a set of sensory triggers. I want to mix live drums with artificial drums.
I figured the best interface for that would be an 8 input interface. I have seen the Behringer umc 1820. Do any of you have any experience with it? I am only interested in the latency specs.
Would the latency be low enough to be able to perform live on stage?
If not, could you recommend any other interfaces (new or old)?
Thanks in advance
Hi!
I am using the UMC 1820 without any trouble.
The moment you hit the drum (with SP trigger of course) you hear the sound.
Before using the Behringer I used an Arturia Audiofuse - I can‘t feel a latency difference.
(Just switched to the UMC because of the number of triggers I am using now…)
thanx very much for the answer
hi guys,
what’s the best (i mean the latency-less) audio interface on the market?
i use an m-audio m-track eight that is good, but despite i have the buffering of the ableton audio engine setted at 64 ms i still feel some small delay (mainly in the fastest patterns).
has anyone found a very good set up to minimize the overall latency?
thanx
I recently tested latencies on the Evans Portal and on the Apogee Element 88, which connects via thunderbolt.
I expected the thunderbolt to be faster, and to my surprise this is not the case at all.
I ran the test several times to be absolutely sure.
Here is a photo showing the measured latencies of two sound cards and different settings, for comparison there is also a measured latency from a Syntakt triggered by midi through Nord Drum 3p pads. One of the tracks shows one-fourth of a second, just for context.
My reasoning is that the latency is created by the software’s analysis of the strokes before triggering the samples, because there isn’t even that much difference when changing the buffer size.
I’m obsessed with latency, but I’d like to stress that I don’t think Sensory Percussion’s latency is something problematic, it’s really small.
Best, :slight_smile:
Artur
The dream has always been to do something rudimental on an electric drum… I would be interested to see how the latency compares between SP2 native, SP2 beta in Ableton, and Streaming options, across the different interfaces with mesh or regular heads using samples with no start silence vs using vsts. I wonder WHY the portal was faster but I’m glad to hear it is.
I’m going to experiment with creating my own streamer with Ableton… Midi via IAC out of SP2, Audio routed via UA console virtual channels.
this is how i’m doing it…The thing w UAD Console that is super frustrating is the IDC setting (that they recommend you use with multiple mic sources to keep them phase aligned). It really messes with the latency tho…Im recording 8 drum mics with the SP2 as a VST all in ableton and am so close to getting the latency settings really tight. Abelton 12 has some interesting options for latency…But using virtual channels to monitor everything is definitely the move and is starting to work really great for me. Last piece of the puzzle figuring out the UAD console drum mics latency measurements and compensating for the playback to be in sync with track delay. Or gonna experiment with Little Labs phase alignment plugin on each durm channel and dialing in the the track delay there.
So I was just testing to see how I could get my latency to below 10ms. The furthest I’ve gotten with testing it out is using my Evans portal as interface and setting it up at 64samps 48kHz in Ableton. I loaded up the VST and tried a snare hit comparing the sensor audio and what comes out of the SP vst and I saw that there’s always about a 15ms delay. Is it true the analysis software takes up about that time and that there’s no way to get it to under 10ms?
Hey all – we just released Sensory Percussion 2.5.0 that reduces the overall sensory latency. Give it a shot and let me know how it feels. You can read more about the release here: Sensory Percussion 2.5 – Upgrade Now
I just tried it out. I never noticed latency from my MBP M2 MAX when just jamming by myself on older SW versions but when playing along with songs I would have a harder time stayiing on beat. I felt it was in part due to latency.
Anyways, with new 2.5 version. I tried playing along with songs and I was staying on beat much better. I don’t have latency numbers but I feel a difference.
Thanks you and the team for putting effort in latency as I think the lower the better always. Thanks.
I’ve tried out the new software and it seems to have improved the sensor latency by 2 ms. I’m not sure if there’s something not right on my end since that changes it from 14ms to 12ms which is still above the 10ms threshold for me to notice flamming in situations where I layer drums with stuff like samples or modeling synths. Do you have any numbers that you can share that came out of in-house testing?
Cheers!
Latency is better to my ears. Will latency be worked on further in the future as well? Thanks.
Yes, we do have some more improvements for latency. Once we get the cymbal features ironed out we’ll be able to get to those. Always improving!
