Live not showing more than 6 inputs despite Portal being connected
Hi! Not too sure what’s going on here – I’m not able to use more than two sensors because the inputs that should be available within Live aren’t. Is there something obvious I’m missing?
Edit: The Portal is selected for both input and output and I haven’t made any changes to the default template.
Hey Rahul,
My first guess is that only inputs 1-6 are active in your Ableton session. If you go to the audio settings window ( ⌘ + , ) and select “input configuration,” you can activate/deactivate your inputs.
Inputs 5-11 on the EVANS Portal are sensor inputs, so you’ll want to activate those according to how many sensors you’re using.
CleanShot 2025-01-14 at 09.59.57
CleanShot 2025-01-14 at 09.58.23
