Hi all there is some good news on direct compatibility of SP on M1 chip?
Yes, SP is now fully compatible with M1 Macs. Head to the downloads page for the update or use the in-app update link.
p.s. if you already tried updating yesterday or earlier today, you will want to re-download and install the update as we fixed a minor issue preventing the plugin from loading on M1’s.
Hey @Tlacael_Esparza I downloaded and installed the new Version (1.8.2.1) and also using a M1 mac (osx 12.0.1). I have issues with the audio streamer (V 1.1.0) in logic. It will not connect to the sensory stand alone plugin. Before I made the update, everything worked fine. Please help!
Update 5 min later:
Ok I opened Logic in Rosetta mode and because of that, it couldn’t connect to sensory. When I open it without Rosetta, its connected. But shouldn’t it also worked with Rosetta?
Hi @ChrisChros909 yes that is what I was going to suggest.
Both SP and the plug-in need to be running in either Rosetta or apple mode for them to communicate with each other as it uses a shared memory block to transfer the data.
