Midi v2 Software
Hallo,
Can I use a MIDI Signal to trigger a sample in the sensory Software?
Thank you,
Julian
hi @Julian - Yes! You’ll want to use the MIDI Pads input type for your MIDI hardware. Then you can use the Grid Pad controller module and it works just the same way as the Drum Pads controller.
Here’s some info on the Pads input: Pad Inputs | Sensory Percussion 2 Help
And the Grid Controller: Grid Pads | Sensory Percussion 2 Help
If you’d rather use the MIDI Input type – you can make MIDI assignments on the Play button of the Sampler or Module you want to trigger. But the Grid Pad method is much easier to setup.
Let me know how it goes.
