Portal Interface not working with Macbook Pro
My Macbook pro m4 running sequoia 15.5 is reading the hardware interface and allows me to assign it however when I do i am not getting any input or output single through the speakers. I used the same said piece of hardware on an older computer running Big Sur and it works just fine. Anybody have any idea how I can troubleshoot this problem? Thank you very much.
hi @Vartan_Duvendjian can you make sure you granted microphone access to Sensory Percussion 2?
Go to settings > Privacy & Security > Microphone and make sure SP2 is listed there.
If that doesn’t work, can you send an email to support@sunhou.se? It’s easier for the team to troubleshoot over there. thanks
Thank you for the prompt response, SP2 was already listed, Ableton wasn’t however I turned Ableton on but still did not work. I will try to email support. Thank you for your time and energy.
