How can you load different zones, e.g. on the snare, with other sounds?
@swissdrummer - you can break a drum into multiple zones using a Drum Pad Controller module.
Just add the Snare Pads controller - add a snare input filter - then drag your samples (or whatever you want) onto the different pads.
If you’re new to Sensory Percussion, I’d recommend checking out the video tutorial series here: https://www.youtube.com/playlist?list=PLd5P60EjzkuNo2m_MOxWCzTzRypH1VSYB
Especially the one called “Intro to Modules” you might find helpful.
