Wondering if it is possible to play 2 page melodic solo with SP? For example some complex jazz solo when I use sampled instruments.
Hi @karla, welcome to the forum!
Could you explain a little more what you have in mind melodically? With Sensory Percussion it’s quite easy to set a pitch shift from center to edge and have it quantize to particular notes, but it would be very difficult to reliably play those notes like on a marimba, for example. Look at the rack tom in this video, for example: https://www.instagram.com/p/B1Hbi7KAaqx/
If you have a specific melody you want to trigger, you could chop each note and put them all on a sampler as a cycle – that each time you hit that zone, it would play the next note.
Let me know if that helps at all.
