Recording live music with X32 and Sensory percussion 2 in Ableton
I am trying to record a live band through my X32 ASIO X-USB Driver in ableton, and I can’t select the Evans portal driver at the same time, it can only be one. I am trying to route the sensors and mix outputs in ableton using the VST in ableton to record at same time we are playing live. But I am having a hard time routing the inputs and outputs in ableton, have any of you tried this? How should I create my mix buses for each sensor to record in ableton correctly without the use of the Evans portal driver?
Hi @Valhalla210 - check out this page on the manual. It has a lot of info about how to do this as well as an Ableton session template that has everything wired up for you.
Give it a shot and let me know if you run into any other issues!
