Replacement cables for V2 sensors
Would I be right to assume that any standard 1/8" TRS cable can be used to connect the sensors to the Portal?
Hi Alex,
Yes, any 3.5mm TRS will work. I’d probably recommend getting a straight cable instead of an L plug because most off-the-shelf L plug cable jacks aren’t long enough to fit inside the well on the top of the sensor. I mean, they’d work, but you’d have to have the cable rotated toward the front of the sensor, rather than going off the side and into the cable capture slot.
You can also purchase replacement cables from the D’addario store. They can ship from the US and Europe, I believe.
Thanks for the quick and helpful reply!
