Is it possible to change the information relating to head type and size for each sensor input after the input has been set for the first time?
Just incase anyone ever comes across this question; It’s not possible! I’ve erased the previous hardware sensor inputs and set up new inputs with the correct head type and drum diameter.
Hi @lupo - that’s right, it’s not currently possible. This is because when you set the head, diameter and drum type, it affects the model that is produced with your training. So changing any of those parameters after you’ve trained a drum could have some weird effects.
So it’s best to delete the drum input and start fresh if you need to make those kinds of changes. Thanks
