I have a new audio interface (motu) and also use a ADAT Audio Interface (Behringer ADA 8200). I only can see the first 4 channels of my motu device in sensory percussion (input matrix) But I want to route the sensors an others channels. Does anyone has the same problem or know how to fix it?
I have a mac and updated to the version 1.3.2 of sensory percussion.
You can route any input channel from you interface to any SP input by using the Input Routing Matrix. If you open up the audio settings menu, you’ll see a “Input Matrix” tab at the top. Just select that and choose the routing you desire.
Let me know if you have any other questions or issues.
thanks for the quick answer
I know that I can use the “Input Matrix” for Input routing, but when I open it, I only see 4 channels of my 10 channel audio interface :-/ - Why?
Can you try toggling the interface to refresh the panel? Select as your output device and then reselect your interface.
There is a known bug where if the interface is disconnected and then reconnected, It will appear to be the active interface in SP but will not actually be connected.
We’re working on fixing that one. Let me know if the above helps.
Unfortunately, that feature was removed when we added the routing matrix. There were some underlying reasons we removed it that I can’t quite remember. But it might make a reappearance in a future update.
Also, quick note: if you need support on Sensory Percussion - the best way to reach the sunhouse team is by emailing support@sunhou.se or starting a chat on the website. That will guarantee the fastest response because it will create a support ticket that our entire team monitors. We definitely watch the forum, but it’s meant more for peer-to-peer support, community, ideas, etc.
