Routing Question
Hi!
Quick question. I’d like a tom to play a sample on channels 1 and 2. Then, I’d like that same tom to play the same sample on channels 5 and 6. But I’d like this to happen very quickly, without changing to another theme.
I thought about using a sequencer, but that doesn’t work because the sequencer only sends to one mix bus.
Maybe using two sequencers synchronized by the same trigger would be a solution? But I guess it’s a bit of a mess…
If someone as a simple idea with this, I’m up.
Hope I’m being clear enough; my English isn’t perfect…
Hey there! Could you explain what you mean by channels? Are you talking auxiliary output channels or something else?
are you saying you want every other hit etc to automatically switch between different outputs but otherwise be the identical sample and effect?
Depending on what you want to do I would nest two groups, samplers or hit controllers inside of a sequencer, and route each of those groups separately. Set up the parent sequence to alternate but you can nest almost anything inside a sequencer, including another sequencer
We do have plans to add sub-module sub-mix routing, at least 1 level down from the layer level. But, until then, you can always use sends. Create two copies of your sample and have each sending to a different send. Then you can sequence the samples and the sends can be routed to sub-mixes. Just dont forget to mute the samples in the submixes.
OK thanks.
Sorry, I was talking about sub-mixes yes.
I think I have my answer here, I simply didn’t think about the send option..!
Really looking forward to a sub-moduke sub-mix routing, would make this kind of thing super easy and even more fun !
Thanks for your quick answers guys.
Appreciated.
Hi there.
@Tlacael_Esparza , I’m starting to work on some multichannel pieces, and I’m wondering if these sub-module sub-mix routing things are still in the dev’ ideas. That would be a blast !
Thanks !
hi @LeMouton good timing! We just released a beta with this feature. You can now send layers one level down to submixes from the Mix page. Check it out here: 2.6.6-beta7 just released
