I’ve gotten the new 2.8 update working pretty well in Superior Drummer 3 with the forum SP2->SD3 template.
Has anyone got the SP2 software properly recording the aftertouch midi chokes in Ableton 12? It is recognized during performance in SD3, but does not playback in Ableton midi clips.
Another issue is that the midi chokes only work when choked quickly, slower grabs of the cymbal do not register.
I’m not sure about the recording issue, but for cymbal choking in SD3 generally, I’ve only had success not using the “afterouch” feature, but instead assigning the choke to a specific MIDI note. Then, in the SD3 MIDI mapping, for each cymbal, you can assign that note to that cymbal’s “mute hit.” So, each cymbal will have its own mute MIDI note, and you need to tell SD3 what notes to listen for. When I do it that way, the chokes work quite welll, fast or slow. To test it out, I’ve left a cymbal resonating for several seconds, and then slowly grab it. The chokes work well. Not sure what I can’t get the “aftertouch” working though…
