Sensory Percussion on Tabla. Questions
Does anyone have any idea if sensory percussion will work on tabla?
Is software included in the purchase of a single sensor?
I already have a sound card so don’t want to purchase the bundle. Ideally I’d purchase a single sensor to test how well it works. Will software be included or is the only way to get software to buy the whole bundle?
I’ve personally tried it on a mridangam (similar to a tabla) while a friend of mine tried it on tabla, and in both cases it does work, with the caveats that
  • attaching them to the drum requires a bit of fiddling since the shape of the drum is obviously very different from drums with hoops
  • the sensitivity between different zones is also tricky since the way the surface of a drum like a mridangam or tabla resonates is extremely different from the way a drumhead on a drum set would
