Sensory V2 plugin Ableton integration
I m struggling to bring SP V2 into my existing Ableton setup.
I tried to merge the Ableton Template with my big Setup
(to launch clips and plugins via CC messages out of SP.)
but the merge doesn’t work because all the Midi mappings doesn’t transfer when I load the tracks from my setup into the template. (reprogramming all the mappings from scratch would be a nightmare)
Apparently the routing in the Template seems to be a special programing…
I tried to do it the old fashioned way with standalone SP connecting to Ableton via IAC Driver bus…
Ableton shows midi signal input but mapping doesn’t work or shows up
I skipped through a lot of Videos but its only for V1.
I wish I could load the VSTplugin into my setup to make all the mappings from there. But this seems to be impossible. There is no sound or signal flow. It only works in the template.
any solutions?
Greets Sebastian
