When dropping the analog delay onto the rim tip pad fx (drum 3) or drum 3 fx it’s acting fonky. Seems like the time or feed is changing on it’s own. If you wait for the tail to end (sometimes), it then sounds like a slapback/flam thing then the feed and time grow apart… idk ! unless i totally missed something
This is indeed a bug. Will fix ASAP. FYI it shuts off when it detects silence (but this fx shouldn’t do that). You’ll notice it doesn’t happen if you put a reverb before it.
Ohhh Rt on thanks, maybe I’ll throw a reverb prev in the chain for now
