Trigger Interface to SP2
Hi there. I own the SP2 system with seven triggers. I was wondering if it’s possible to use single zone pads via a trigger interface and midi into the sp2 for extra sounds? I thought seven would be enough but it isn’t. I was hoping to use a ddrum DDT with 10 trigger inputs. I’d love to add some extra sounds using this but if it’s not possible I can save the cash. Also if it’s possible, my next question is can sound switching be done for these using the SP2 from the sp2 triggers and the SP2 brain or are they stuck with whatever is assigned?
