I’m having trouble mounting the Sensor on a S-hoop(slingerland) rim. The Sensor is not parallel and it’s leaning down. Any suggestions? I tried loosening the lugs by the sensor and it didn’t help. I’m also using mesh heads.
Hi @Nickysick, are you using v1 or v2 sensors?
If v2, another user had this issue and was able to get the sensor parallel by simply tightening it down much harder on the drum. Don’t be too shy when tightening!
